Ping interval problem with template icmp ping
  • david_zab
    • Nov 2023
    • 10
    Hi all,
    I have a cluster of 3 zabbix server on 6.0.23, and I have a problem with the interval of the ping check on certain devices with the icmp Ping template (Template Module ICMP Ping, Template tooling version used: 0.38​)
    For all devices except linux devices, the interval between ping chek is 7 seconds...
    On the template the interval is on 1 second. I try to manually uptade to 2 seconde but same problem, and the linux devices are always OK with the fixed interval... But all others device (windows, network device etc...) have the 7 seconds interval....
    I try too to add agent pinger on the servers but same problem, and the process pinger is very low on the data from the server zabbix template...
    If you have an idea please, it's very important for me to have check every minut for the ping, I never have this problem on Zabbix server 5.2
    Have a good day, best regards
  • david_zab
    • Nov 2023
    • 10
    I find the solution, I forgot the proxy, and by default the zabbix proxy have juste one agent pinger.... I modified configuration to have 20 pinger agent and it's OK
    Sorry for my post but maybe it can help anyone.
    Have a good day!
