Zabbix Action Condition - High Severity doesn't work
  • asteroidyorkton
    • Aug 2016
    • 53
    My action works fine for all Severity and "Trigger name not like" except for high trigger. I don't get Zabbix Unreachable emails. Emails should be sent to zabbix super admin group.
    Removing all severity and keeping only High trigger works. When I add back other Severity, Triggers does not email me.
    My condition screenshot:
  • LenR
    • Sep 2009
    • 1011
    I read the first image as all "ands", so the parentheses are irrelevant.
    Trigger severity can only have one value, so TS = Disaster AND TS = High can't both be true, I don't need to go any further.
    • asteroidyorkton
      • Aug 2016
      • 53
      Okay. I'll try a custom condition then
      • LenR
        • Sep 2009
        • 1011
        () just control evaluation order, resolve deepest () to a single T / F, then work up to higher levels.
        I can't determine from your questions what you are trying to do. Make simple actions, get those working, add as little complexity as possible.
        Actions that notify users/groups require those users have permissions to those systems, have you verified permissions?
        We wanted some triggers to notify our platform support teams, instead of making complicated actions, I created an application called "Platform" and use a single condition for that. We also use severity for notification method, Average gets email, High gets wakeup message :-)
        • asteroidyorkton
          • Aug 2016
          • 53
          Okay. Yes permission was verified and also the severity settings for user..
