Trigger when zabbix receive a specifc error when trying to connect to database?
  • solaireofastora
    • Nov 2023
    Is there a way to trigger when zabbix receive a specifc error when trying to connect to database (and anything else)
    I'd like to trigger an alert when zabbix try to connect to the database and receive only ORA-01033 error
    It is an error message, why your item has turned to "not supported" state. You cannot use that in alert generation...
    There are "internal actions" which allow you to alert someone in case of items turning to not supported state, but even there you cannot choose so detailed condition, there's host/host group and tags/tag names and couple of different events available, but that's it..
    • Hamardaban
      • May 2019
      • 2714
      To control the connection to the database, you can make a script in which you try to establish a connection via odbc and return the result.
      And execute it in item and process the return value
