Agent2 system.run error ZBX_TCP_READ() timed out
  • Brambo
    • Jul 2023
    • 256
    On a host is have 3 system.run commands 2 of them run fine.
    The third one which takes about 6 seconds processing time gives the mentioned error.
    So in the zabbix_agent2.conf (windows agent) I set the timeout to Timeout=15
    Where the word Timeout start at the first characters of a new line.
    However when executing the the command from test option on host level I keep getting the error.
    The command i run =
    system.run[powershell.exe -c "$UpdateSession = New-Object -ComObject Microsoft.Update.Session ; $UpdateSearcher = $UpdateSession.CreateupdateSearcher() ; $UpdateSearcher.Search('IsHidden=0 and IsInstalled=0').Updates | Select-Object -expandproperty Title", wait]
    First I expected that my agent2 version was mismatch with the server was a potential error but before posting this i made sure those are both the same version
    The error "error ZBX_TCP_READ() timed out" comes in about 3 to 4 seconds in the server Gui. When I make the powershell code faulty then I get an error output of the command so it does land on the host.
    Agent2 version 6.4.8, Server 6.4.8
  • Answer selected by Brambo at 15-11-2023, 15:52.
    cyber
    • 4993
    There is a timeout option is server/proxy config too...
      • 4993
      • Brambo
        • Jul 2023
        • 256
        Changing the setting in the server as well did the trick
