Hello everyone, I have been trying for a few days to get my zabbix server to ping the google IP 8.8.8.8 through a host that is a router, for this I have created my host (Router) with its IP which does a simple check (does not use zabbix agent) via snmp, then I have created the Item called "Internet Test" that will ping Google through my host, icmpping[8.8.8.8] is the monitor, and then I have created the trigger, last(/host/icmpping[8.8.8.8],#3)=0. Up to this point I think everything is correct, at least at the syntax level and following the guide in the official Zabbix manual, but when I restart the router to check, it is still operational, can you help me? Thanks in advance.
