Zabbix agent emulator for as400 system
  • Genya94
    • Nov 2022
    My team is starting a transformation from an old monitoring system to a Zabbix environment and part of the system we monitor is an AS400.
    I found this link to the Zabbix community - https://www.zabbix.com/integrations/as400
    Does it work with the latest Zabbix version 6.4? and is there maybe a guide on how to implement this kind of agent emulator?
    Any help will do as we are just starting with Zabbix.
    Thank you in advance!
  • Kos
    • Aug 2015
    • 3469
    Hi, Genya94!
    I hope, this link will help you. As the author of this project, I monitor that forum thread and try to reply in a reasonable time
    Yes, this agent emulator should work with Zabbix v6.4, too. The only issue is that it will not reflect the status of Active mode Agent in the "Availability" column on some screens like "Monitoring" -> "Hosts" (link). The previous versions of Zabbix did not monitor the availability of active agents at all; this feature has been added since v6.2 (extending the existing protocol used by agents in an active mode). However, the as400 agent emulator still does not implement this protocol extension due to lack of needed information. However, this is just a cosmetic issue - all its existing functionality should work OK.​
    • Genya94
      Genya94 commented
      Hi @Kos,
      First of all thank you for your comment and thank you for that project.
      Somehow I'm missed the readme.pdf file so I didn't fully understand how to make the agent emulator work but now it seems really simple.
      I just have one question, in the "Start of program" section under the second case of connection you wrote that there's need to be a network access between the server the agent is on and the as400 system, what network access you meant? SSH port 22? And what credential I should supply in their conf file? The password for the as400?
      Thank again for your help!
  • Kos
    • Aug 2015
    • 3469
    Hi!
    The AS/400 clients (including the IBM Toolbox library) use some number of network ports to connect to different services (see the as400.service[service] metric and the isConnected(service) method used to implement this check). Probably, it's a good idea to find the list of ports used by these services by default, and include it in the README file, too.
    Credentials - yes, the username and password of the user profile on the as400.
    Update: see here for info about the network ports (link).
    • wuhaohust
      • Jan 2025
      • 10
      Originally posted by Kos
      Hi!
      Kos, may I know what's the required privilege for the user which used for as400 monitoring ?
      • Kos
        • Aug 2015
        • 3469
        You need a user on as400 system (either to start the Java process for local agent running, or to connect as this user for remote mode).
        This user does not require any special privileges in default setup; but it may be necessary to assign some privileges (like *JOBCTL for job monitoring) if you performed hardening of your OS.
        • wuhaohust
          wuhaohust commented
          Kos thanks, we use the agent and successfully collected the data. If we need some other metrics (like disk busy rate, asp overflow), how can we get that ... I am not familiar with java....really appreciate if you can help with this
      • wuhaohust
        • Jan 2025
        • 10
        Now we successfully run the agent on our as400 devices, and we also added the function to calculate the disk busy with (total sample count - non busysample count)/total sample count ,everything is working fine. But on 1 device, we received an alert "zabbix agent(active mode) is unreachable ", agent is still running and in the logs we can see below messages,it looks like the agent still collecting the info and just failed to upload the data? May I know if there is any retry Mechanism to avoid such issue ?
        70:20250718:211938.921 active check data upload to [xx.xx.xxx.xxx:10051] started to fail
        69:20250719:000004.188 Procstat.updateJobinfoList() error: com.ibm.as400.access.AS400Exception: CPF3C53 Job 254470/QSYS/QYMEARCPMA not found.
        69:20250719:012912.656 Procstat.updateJobinfoList() error: com.ibm.as400.access.AS400Exception: CPF3C53 Job 254881/QUSER/QZSOSIGN not found.
        69:20250719:014939.330 Procstat.updateJobinfoList() error: com.ibm.as400.access.AS400Exception: CPF3C53 Job 254976/QUSER/QZSOSIGN not found.
        Kos
        • Kos
          • Aug 2015
          • 3469
          Kos
          Hi @wuhaohust,
          first of all, insure that you are using the last available version (0.7.9 at the moment, see here). The Agent writes the version number to the log file during startup, you can check it.
          Yes, the Agent has a retry mechanism to send any information collected during unavailability period.
          However, your quoted messages (besides the first line) don't relate to the Agent' availability; they are just warnings that some jobs don't exist anymore.
          You need to investigate why there is a communication issue. If the passive mode checks work OK, but the active mode checks fail (additionally, on one specific host only), then it is, most probably, a configuration problem. Check the following moments, please:
          • communications from the Agent to Zabbix Server (IPv4, tcp port 10051) are not blocked by any firewall;
          • parameter "ServerActive=" in the Agent's configuration file contains the correct IP address or DNS name of the Zabbix Server;
          • parameter "Hostname=" in the Agent's configuration file contains the correct name of Zabbix host. It must have exactly the same value as the "technical" ("Host name" field, not "Visible name) name of this host in a Zabbix web interface.
          I hope, this helps.
          • wuhaohust
            wuhaohust commented
            thanks for your reply. Yes, it's actually a connection issue, after upgrade the san switch , network connection changed and the 10051 is blocked, it's not a agent issue
        • wuhaohust
          • Jan 2025
          • 10
          Hi @wuhaohust,
          I hope, this helps.
          Kos is it possible to specify which IP to be used for active check? we have multi IPs on as400 and only 1 IP connection is allowed , now the connection is from another IP and the connection is blocked
          • Kos
            • Aug 2015
            • 3469
            wuhaohust , good question.
            Actually, Zabbix Agent recognizes the "SourceIP=" parameter in the config file, but ignores it
            So, unfortunately, at the moment - the honest answer is: "no, it's impossible right now".
            However, it is a good point for me to implement this feature in some next version (I don't think it is too difficult).
            • jorven16
              • Jul 2025
              Yes, the AS400 integration works with Zabbix 6.4. You can find guides on the Zabbix community page and forums. Start by following the steps in the link you shared and ask in the community if you need help. Good luck!
              • Kos
                • Aug 2015
                • 3469
                Hi guys,
                I have some good news. I had some time to update my project, so now I can give you a preliminary announcement about a new version.
                I'm still not ready to publish it in public (it is not tested enough, documentation is still not ready); but, maybe, someone wants to try it now? If yes - contact me, please.
                What's NOT changed:
                • interaction with the host system (system i, AKA AS/400 or as400), so no new information we can get about this system;
                • base limitations: no IPv6, no encryption, no active-only mode (i.e. minimum value for the StartAgents parameter is 1).
                What IS changed:
                First of all, the previous version was written several years ago, so it uses code base of Zabbix v3.0. Since that time, there were a few versions of Zabbix (and several tens of releases), in particular - some modifications took place in protocol used for communications between Zabbix Server/Proxy and Zabbix Agent. So, the main change is: now our Zabbix agent emulator supports the current version of this protocol. It pretends to be a real Zabbix Agent v7.0.0 for Zabbix server/proxy (agent variant 1).
                Therefore it support such things as:
                • heartbeats (added in Zabbix v6.2);
                • incremental configuration update (added in Zabbix 6.4);
                • Zabbix server clustering (added in Zabbix 6.0) and Zabbix proxy clustering (added in Zabbix 7.0), including redirection messages;
                • custom intervals for active mode (both flexible and scheduled intervals) (!)
                Additionally, all configuration parameters were reviewed. Now they can be processed by one of the following ways:
                • unknown parameters: error message and failure to start (it is the same behaviour as before);
                • recognized, but not implemented parameters (like "TLS*" or "LogType"): ignore, but write a warning to the log file;
                • recognized, but implemented: should be really used.
                For example, the following parameters now are really used or have been modified:
                • AllowKey/DenyKey (with "our" metrics "agent.exit" and "agent.debug.active.thread" - denied by default);
                • Server (is mandatory now, but currently it supports CIDR subnets);
                • ServerActive (can contain clustered configurations);
                • HostMetadata and HostMetadataItem: increased allowed length (from 255 chars to 2034 bytes and 65535 chars accordingly);
                • Alias (was not used before);
                • ListenBacklog (was not used before);
                • SourceIP (was not used before, hi wuhaohust ​);
                • HostInterface/HostInterfaceItem, ListenPort and ListenIP parameters are really transferred (if they are) during autoregistration of active agent.
                ​Finally, some new metrics was added:
                • agent.hostmetadata
                • agent.variant
                • vfs.fs.get​
                • as400.disk.get
                • as400.systemPool.get
                The "*.get" metrics return JSON's that can be used for both LLD and current values extracting.
                All "*.discovery" metrics now returns just arrays, without the "data" element (it was removed in Zabbix v4.2, so I don't think it is used by somebody now).
                So, at the moment I'd like to ask:
                • does anybody interesting in support of _lists_ for the ListenIP parameter? Officially, Zabbix Agent supports list of IP addresses in this field; but we support only a single address (by default - 0.0.0.0 for "any").
                • can anybody test the current build in real clustered configuration? We don't have clusters in our installation, so I can't really test all conditions :-( If someone can confirm that it works as designed, it will be great :-) Ideally, for both clustered configurations - Zabbix server and Zabbix proxy.
                Sincerely yours,
                Constantin Oshmyan​
                • mduza27
                  mduza27 commented
                  Hi Kos,
                  i would like to test the new agent please share for download
              • sancho
                • Mar 2015
                • 301
                Hi Kos,
                We don't have a cluster in our infrastructure either, so I wouldn't be able to help you with that, but for any other tests you need, I could try setting them up in our development environment.
                If you think I can help, contact me privately.
                Best regards.
                • Kos
                  • Aug 2015
                  • 3469
                  See personal message, please.
                  • sancho
                    • Mar 2015
                    • 301
                    Hello Kos, I’ve sent you an email to your Gmail account with what I’ve found so far during the tests.
                    • Kos
                      Kos commented
                      OK, answered.
                  • Kos
                    • Aug 2015
                    • 3469
                    #15
                    Some news, guys.
                    This project is close to the finish line. It has V0.8.0-beta3 now, that probably, will become a release soon.
                    The main changes (long-waited):
                    • new metrics:
                      • as400.sql.select
                      • as400.sql.get
                      • system.uptime
                      • system.run
                    • other:
                      • the "UserParameter=" option of config file was implemented.
                    Some details:
                    The as400.sql.select and as400.sql.get metrics are just analogs of the db.odbc.select and db.odbc.get metrics (accordingly), but they don't require any ODBC drivers (as they use JDBC driver instead). It allows to use system views to collect any available information, for example:
                    • select a single value: number of active jobs:
                    as400.sql.select["SELECT COUNT(*) FROM TABLE(QSYS2.ACTIVE_JOB_INFO(JOB_NAME_FILTER => '*ALL', DETAILED_INFO => 'ALL')) X"]
                    • select a JSON with all information about top-5 jobs:
                    as400.sql.get["SELECT * FROM TABLE(QSYS2.ACTIVE_JOB_INFO(JOB_NAME_FILTER => '*ALL', DETAILED_INFO => 'ALL')) X FETCH FIRST 5 ROWS ONLY"]
                    • select info about network interfaces:
                    as400.sql.get["SELECT * FROM QSYS2.NETSTAT_INTERFACE_INFO​"]
                    The system.run metric was the most troublesome, as it should return the stdout/stderr streams, but system i (as400) does not have a concept of stdout/stderr at all; so it was absolutely unclear how to implement this metric. The solution was borrowed from IBM: in their product IBM Tivoli Monitoring they used a Qshell call for custom scripts. This approach is really working: a Qshell supports a lot of features, including:
                    • the stdin/stdout/stderr concept, as well as pipes;
                    • a lot of "usual" for *NIX-admins utilities (like echo, ps, ls, cat, head, tail, grep, xargs, etc.);
                    • the "system" command that allows to call a standard CL commands and receive their results as stdout/stderr.
                    Unfortunately, there were some small technical problems to get it working, but now we can use something like the following (just an example):
                    • Output top-5 jobs sorted by total CPU usage:
                    system.run["system -q 'WRKACTJOB SEQ(*CPU)'|tail -n+11|head -6"]
                    The implementation of system.run metric allows to implement the "UserParameter=" option of config file, too. So, now we can use the command from the last example as a User parameter:
                    UserParameter=MyMetric,system -q 'WRKACTJOB SEQ(*CPU)'|tail -n+11|head -6
                    ​or even with a parameters:
                    UserParameter=MyMetric[*],system -q 'WRKACTJOB SEQ(*CPU)'|tail -n+$1|head -$2
                    Sorry, I missed the most important part: link (to my Google Drive).
