How to insert values direct into zabbix Mysql Database
  • DanielFRocha
    • Dec 2014
    • 37
    Hi I need help with a Zabbix problem,
    I need to insert data with timestamp once in a day
    but I need to insert this data in the past moment
    I have the algorithm to only brings me the number like ex:
    bring only the room number in data 08/27, but i need to insert this number into the Mysql (Maria DB) Database from zabbix.
    The output will be like that:
    data: 08/27 room: 12456 mobile: 9456
    data: 08/28 room: 13770 mobile: 10350
    data: 08/29 room: 10380 mobile: 11728
    data: 08/30 room: 14560 mobile: 5845
    Thanks in Advanced.
  • SBO
    • Sep 2015
    • 226
    I would use a flat text file with all your data, and send it through zabbix_sender.
    Format to use :
    <hostname> <key> <timestamp> <value>
    Timestamp is in epoch (unix timestamp) format, even if you're doing this on a windows host.
    Example :
    mynode.intra 1472651733 my.key.in.zabbix value.of.the.key
    • DanielFRocha
      • Dec 2014
      • 37
      Hi
      Thanks for you help, but how can I specify to adjust just a dot in an time the zabbix_sender is add this value in the last 3 days even if with a timestamp configurated.
      I am using this command:
      zabbix_sender -z 127.0.0.1 -T 1472688000 -s "Test Server" -k test -o 164332 -vv
      Thanks in Advance.
      • Semiadmin
        • Oct 2014
        • 1626
        Hi, DanielFRocha.
        You'll have to create a file (for example, /tmp/test.txt) with text like this one:
        "Test Server" room.12456 1472688000 9456
        "Test Server" room.14560 1472687500 5845
        where room.12456 and so on - item.keys.
        After that you can use command
        zabbix_sender -z 127.0.0.1 -i /tmp/test.txt -T -vv
        zabbix_sender -T don't work without a file
        • DanielFRocha
          • Dec 2014
          • 37
          Thanks my friend,
          I will Try for sure.
