Ladies and Gentlemen,
Zabbix has made me small and insignificant.
I got a request from the CTO to create a report that shows the downtime for a store only when that downtime falls into the time that the store is open.
I have about 90 stores spanning from Col to NY and I'm pretty far down the rabbit hole.
I have a lot of gear, but for simplicity sake lets focus on a sonicwall firewall.
I have the host.
I am doing snmp (and ping) using the generic SNMP poler and all of that is fine.
I have created a trigger that will work based on an item that will look at the store start time and end time values that I have created as a macros (not the best way as I"m doing UTC on the server and that is making the times span past 00:00 and I had to create multiple macros dealing with that.
(open to suggestions but not my primary issue)
So I have that trigger and it looks at time and also looks at the ping loss trigger that looks for 3 in a row and then triggers.
So This makes my custom trigger trigger
But I can't graph a trigger. and since it's not part of a template I can't do the availability report on it either.
I have been trying to create a zabbix trapper object and populate that from the trigger but I can't figure out how to do the sender script based on the trigger..
So I'm pretty far into the weeds but the goal is to have my trigger trigger.
Have a long graph for each store so that it will graphically show the data and when there was any downtime that affected the store.
I also need another widget that shows the total downtime (custom trigger time) and hopefully even pull out the day and times affected for the store.
I have been focusing on trying to natively do all this, but if I had to at this point I would open a vein ... I mean.. write a PowerShell script to populate the trapper if that is the way to do this.
It has taken me way too long to figure this out and I hate asking for help as I feel like I'm not learning what I should learn, but maybe I'm just too old and need some young very smart person to tell me what to do?
I could seriously use some help and please let me know if you need specifics instead of what I'm trying to do.
Thank you in advance for your very valuable time.
I have the host.
