Zabbix aggent testing an item with comma in parameter
  • aleksander237
    • Apr 2022
    • 13
    i'm trying to test some items under windows 10. This works:
    zabbix_agent2.exe -t wmi.getall[root\cimv2,"select Name from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]
    this does not:
    zabbix_agent2.exe -t wmi.getall[root\cimv2,"select Name, Description from win32_networkadapter where PhysicalAdapter=True and NetConnectionStatus>0"]
    the second command gives me the error "Invalid number of parameters". I'm assuming that the problem lies in comma used in query.
    How do you escape commas ?
    Best regards,
    Aleksander
  • Semiadmin
    • Oct 2014
    • 1626
    Hi. The key looks good. Try to test it from Zabbix GUI by Test button on the item configuration page.
    I suppose this is a problem of the shell.
    • aleksander237
      • Apr 2022
      • 13
      Hello, the key is for sure good as this the modified zabbix's original key for item "Windows: Network interfaces WMI get". So i know it works, but I want to test more wmi queries and i don't want to use zabbix gui all the time. I want to test it locally on machine with zabbix agent. There must be (should be) way to escape these commas in the query (parameter). I've already checked backslashes, and other magic tricks. The official documentation does not help.
