keeping track of website scenarios "response code" history
  • funkoolow
    • Jul 2020
    hello everyone,
    this is my first post so I hope this will not be considered a dumb question!
    I'm using a Zabbix 6.0 setup on which I created a host connected to an agent on a remote Linux machine, setting the correct template and receiving all standard infos provided by the remote Linux Agent, all fine up to here.
    Then I created a web scenario to monitor a website published by the mentioned Linux Server, setting the check on status code 200, and here also is all fine.
    What I'm now trying to accomplish is to record the status codes obtained over time, since if I'm not wrong the basic template just keeps records of "speed" and "response time" value in the details of web scenario page, reporting just the last status code recorded. In other words, I'm interested in keeping track of how may times the check on "code 200" is true over time, with a graph just like the detail page offers for "speed" and "response time", ideally reporting also the different response codes recorded at every check (404, 501, 502, 505) - but if thats not possible even a yes/no "code 200" will be fine.
    thanks everyone for any help in any case ​
    https://www.zabbix.com/documentation...rio-step-items
    Response code for step <Step> of scenario <Scenario>
    Probably need to add some calculated items, which count your needed response codes in specified time...
