Adding Grafana to Zabbix appliance?
  • EmilK
    • Nov 2023
    Hello folks.
    I've successfully installed Zabbix appliance and have it monitoring 20 servers and devices.
    I wanted to add Grafana to it, but having hard time installing it. Mainly, not being able to import gpg key for grafana repository.
    Does it have anything to do with appliance limitations, or am I know doing something write?
    i was going by grafana install instructions for CentOS.
    thank you
  • LenR
    • Sep 2009
    • 1011
    Error message?
    • EmilK
      • Nov 2023
      Hello LenR,
      I was following instruction on installing Grafana.
      First step was wget gpg key, then import it
      [root@appliance ~]# sudo rpm --import gpg.key
      error: gpg.key: import read failed(0).
      it just won't do it.
      • Brambo
        • Jul 2023
        • 256
        Originally posted by EmilK
        Hello LenR,
        So is that gpp.key file in the root of your appliance? of is it maybe located in a different path? It basically says it cant read the file/ there is no file? So either the file you have is corrupted or there is nothing
