Create a trigger for files bigger than "x" MB
  • Fabrizio We BiNar
    • Nov 2023
    • 9
    #16
    yes, all of these files are located in c:\test\dicom, no subdirectories.
    • Semiadmin
      • Oct 2014
      • 1626
      #17
      Then I don't know how you get 0, sorry
      • Fabrizio We BiNar
        • Nov 2023
        • 9
        #18
        If I can get the item to return "1", you think that the trigger code is fine for my purpose?
        • z0nk
          • Oct 2024
          • 45
          #19
          How can I make vfs.dir.size return output in MB or GB, not Bytes?
          • ISiroshtan
            ISiroshtan commented
            If you want it to be translated on graphs and overview in latest data - just add unit type for item as "B"
            If you want it to be stored in DB and shown in latest data actual values view (rarely needed) - preprocessing with custom multiplier of 0.0009765625. 1 step of this preprocessing for KB, 2 times for MB, 3 times for GB
        • z0nk
          • Oct 2024
          • 45
          #20
          ISiroshtan, thanks. The problem was I didn't declare 'b' in Unit, then it started calculating MB/GB/TB etc regarding to size
          • jurgen16
            • Jul 2023
            • 13
            #21
            You can use this kind of key if you want to receive an alarm but this case works if normally you don't have files with size more than 260 MB.
            And this will create an alarm everytime that you will have one or more file with size more than 260 MB.
            Item key: vfs.dir.count[C:\test\dicom,,,,,,260000000,,,,]
            Alarm exxpression: last(vfs.dir.count[C:\test\dicom,,,,,,260000000,,,,]​​)=0​
