Stop item preprocessing automatically ignoring leading zeros
  • vanmaelst
    • Sep 2023
    An SNMP item is sending a 64 bit bitmask, like "000101000000000000100000000000000000000000000 0000 000000000000000". For some reason, the least significant bit is to the left in this notation.
    I know the flag which each bit represents, and have written a javascript preprocessing step that converts this into a string with more verbose information about the flags, but I notice that even though I only specify to right trim the zeroes, as soon as I do any operation on this incoming value, it automatically ignores the leading zeroes:
    (so the resulting string contains incorrect information)
    I'm fairly certain it's not a javascript issue. Inside javascript, the trimmed string is treated as a binary number, but zabbix seems to treat it as an integer. Is there any way to stop this behaviour, or maybe add a fixed number (2^64) to create a nonzero least significant bit?​
  • Hamardaban
    • May 2019
    • 2714
    When multiplied by a number ("Custom multiplier" step), the type is automatically converted from string to number w\o leading zero.
