Separate widget for every host
  • RomeoKh
    • Nov 2023
    Hello everyone!
    I know there is host availability widget exist in Zabbix dashboard. I wonder if it is possible to make separate widgets for every host in my network? Somthing like green rectangles for available hosts and red for down ones, so technical staff could instantly see there is a problems. I can't find the proper widget
    Sorry my english.
    Romeo
  • Brambo
    • Jul 2023
    • 256
    From zabbix 6.4.0 and higher you can make background changes on a widget. Using widget type Item Value Click image for larger version  Name:	image.png Views:	0 Size:	6.9 KB ID:	474511
    And then in treshhold do something with a certain value. In my example a 0 is critical value and 2 = all clear. Which values to use for agent availability is something you should look for yourself.
    • RomeoKh
      • Nov 2023
      Quite good workaround, thank you! Time to upgrade to 6.4
