How to execute e begin block code and select in zabbix database monitor using odbc?
  • solaireofastora
    • Nov 2023
    I can't write the exact PL/SQL block I am trying to execute, but is something like this example:
    begin
    null;
    end;
    select * from dual;
    it does not work, neither in zabbix or sqlplus
    the code bellow works in sqlplus, but does not work in zabbix because it does not undestand the /
    begin
    null;
    end;
    select * from dual;
    How can I execute a begin block code (I need to execute it to process the value) and the select to retrive the value.​​
    The code above is only a example, the point is execute a begin block and then a select query.
