Cannot load Zabbix Frontend module
  • D_Y
    • Nov 2023
    I am unable to load any frontend module on my zabbix server (version 6.0.23) by uploading the module directory to /usr/share/zabbix/modules/
    I even tried the tutorial to create a basic module - https://www.zabbix.com/documentation...torials/module and loaded MyAddress/manifest.json
    but still when I go to Administration > General > Modules and run Scan Directory, I always get an empty list with "No new modules discovered".
    I also tried chown -R the dir to be zabbix or www-data user, but no change.
    Can someone help me troubleshoot?
  • D_Y
    • Nov 2023
    Any help please?
    • solution
      • Jun 2020
      • 271
      Pre-requisites:
      Wellington
      • D_Y
        • Nov 2023
        Thanks, I think I have ticked all the pre-requisites - although the first prerequisite listed on that page says
        "The module is located inside the modules directory of your Zabbix frontend installation (for example, zabbix/ui/modules).​"
        which seems to imply the modules directory could be at different locations based on a specific install.
        But nowhere in documentation did I find a cli cmd or the location of a conf file where I can verify the actual path of the modules directory on a particular zabbix server?
        • solution
          • Jun 2020
          • 271
          If you installed using yum/apt packages the default directory of Zabbix frontend is:
          /usr/share/zabbix
          Wellington​
          • ida.djurhuus@regionh.dk
            • Dec 2023
            I have a similar problem and I put the module in the zabbix/ui/modules directory but the scan doesn't find the module.
