Fancy Pie Charts
  • mrogers-9898
    • Sep 2008
    • 68
    Fancy Pie Charts
    ​Hey all,
    I'm trying to figure out how I can display a change in a pie chart and display the change for a time range, but I'm not sure of the right way to go about it.
    To try to better explain, the graph would show the
    • current value - the difference in value for the time range
    • the difference in value for the time range
    • graph sum value
    Example: the current value is 75%, the change over the period was 25%.
    Example chart
