Trigger prototype gets created under wrong template
  • asteroidyorkton
    • Aug 2016
    • 53
    Zabbix 3.0.5rc1
    I have a Custom SNMP interfaces template which was a exported copy of Tempalte SNMP Interface and modified and reuploaded as Custom SNMP interface.
    Now whenever I create a trigger prototype under ANY template, it ends up in Custom SNMP interface and all its hosts gets the tirgger prototype. Its getting annoying and Looks like I can't create trigger prototype for any other template.
    At first I thought it was only happening for Template SNMP interface template, then I tested it on other templates, everything goes under Custom SNMP interface template, "Network Interface UP" discover rule, trigger prototype.
    I tested by creating a different Discovery rule for another template which was successfully and under that I created a trigger rule which ended up in Custom SNMP interface (Under network interface UP - trigger prototype). My next option is to try deleting Custom SNMP interface and test.. Which I really don't want to try now, its liked to a lot of devices.
  • asteroidyorkton
    • Aug 2016
    • 53
    my mistake
    Errr.. The trigger expression I was adding under Trigger prototype had the expression starting with Custom SNMP interface instead of the actual template name. That's why it all ended up on that template.
