monitor the Memory and CPU of my ubuntu server with SNMP
  • Vaibhav Ubale
    • Mar 2021
    • 9
    Hi ,
    I want to monitor the Memory and CPU of my ubuntu server with SNMP but only getting uptime and some basic information.
    Item for SNMP template attached shows the error "no such object against OID for Agent" for memory and CPU.
    Can some expert help me with this
    I have already installed the MIB downloader but no luck.
    Thanks in advance.
    Vaibhav​
  • Answer selected by Vaibhav Ubale at 16-04-2024, 13:03.
    ISiroshtan
    • Nov 2019
    • 324
    You need to allow the agent to provide data in OID trees needed for monitoring. I would start with simple test of adding
    view systemonly included .1.3.6.1
    After that restart snmpd and check again if data starts flowing in. If all works - you can then work on hardening allowed tree (if you really want/need to do it).
    To explain:
    In configuration
    view systemonly included .1.3.6.1.2.1.1
    you define "view" (a collection of OID trees that SNMP user using that view will be able to access) with the name "systemonly" to "include" (add to allowed to view trees) all oids that start with .1.3.6.1.2.1.1 .
    Because OID requested by Zabbix starts with 1.3.6.1.4, it does not match any currently included trees. By allowing pretty high level OID .1.3.6.1 I hope it will include all you need to your monitoring
    • vijayk
      • May 2023
      • 305
      Did you check with snmpwalk command? Does it returns the value?
      • Vaibhav Ubale
        • Mar 2021
        • 9
        Hi Yes!!
        I have checked the snmp walk and i dont see the OID in it ...
        This is my snmpd.conf ...
        sudo cat /etc/snmp/snmpd.conf |grep -v '^#\|^$'
        [sudo] password for gargi:
        sysLocation Sitting on the Dock of the Bay
        sysContact Me <[email protected]>
        sysServices 72
        master agentx
        agentaddress 192.168.0.110,127.0.0.1,[::1]
        view systemonly included .1.3.6.1.2.1.25.1
        rocommunity Dpublic default -V systemonly
        rouser authPrivUser authpriv -V systemonly
        includeDir /etc/snmp/snmpd.conf.d
        and
        snmp walk out put is as below
        snmpwalk -v2c -cDpublic 192.168.0.110
        Timeout: No Response from 192.168.0.110
        [root@pczbcl1 ~]# snmpwalk -v2c -cDpublic 192.168.0.110
        SNMPv2-MIB::sysDescr.0 = STRING: Linux BlackJack 6.2.0-37-generic #38~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Nov 2 18:01:13 UTC 2 x86_64
        SNMPv2-MIB::sysObjectID.0 = OID: NET-SNMP-MIB::netSnmpAgentOIDs.10
        DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (574) 0:00:05.74
        SNMPv2-MIB::sysContact.0 = STRING: Me <[email protected]>
        SNMPv2-MIB::sysName.0 = STRING: BlackJack
        SNMPv2-MIB::sysLocation.0 = STRING: Sitting on the Dock of the Bay
        SNMPv2-MIB::sysServices.0 = INTEGER: 72
        SNMPv2-MIB::sysORLastChange.0 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORID.1 = OID: SNMP-FRAMEWORK-MIB::snmpFrameworkMIBCompliance
        SNMPv2-MIB::sysORID.2 = OID: SNMP-MPD-MIB::snmpMPDCompliance
        SNMPv2-MIB::sysORID.3 = OID: SNMP-USER-BASED-SM-MIB::usmMIBCompliance
        SNMPv2-MIB::sysORID.4 = OID: SNMPv2-MIB::snmpMIB
        SNMPv2-MIB::sysORID.5 = OID: SNMP-VIEW-BASED-ACM-MIB::vacmBasicGroup
        SNMPv2-MIB::sysORID.6 = OID: TCP-MIB::tcpMIB
        SNMPv2-MIB::sysORID.7 = OID: UDP-MIB::udpMIB
        SNMPv2-MIB::sysORID.8 = OID: IP-MIB::ip
        SNMPv2-MIB::sysORID.9 = OID: SNMP-NOTIFICATION-MIB::snmpNotifyFullCompliance
        SNMPv2-MIB::sysORID.10 = OID: NOTIFICATION-LOG-MIB::notificationLogMIB
        SNMPv2-MIB::sysORDescr.1 = STRING: The SNMP Management Architecture MIB.
        SNMPv2-MIB::sysORDescr.2 = STRING: The MIB for Message Processing and Dispatching.
        SNMPv2-MIB::sysORDescr.3 = STRING: The management information definitions for the SNMP User-based Security Model.
        SNMPv2-MIB::sysORDescr.4 = STRING: The MIB module for SNMPv2 entities
        SNMPv2-MIB::sysORDescr.5 = STRING: View-based Access Control Model for SNMP.
        SNMPv2-MIB::sysORDescr.6 = STRING: The MIB module for managing TCP implementations
        SNMPv2-MIB::sysORDescr.7 = STRING: The MIB module for managing UDP implementations
        SNMPv2-MIB::sysORDescr.8 = STRING: The MIB module for managing IP and ICMP implementations
        SNMPv2-MIB::sysORDescr.9 = STRING: The MIB modules for managing SNMP Notification, plus filtering.
        SNMPv2-MIB::sysORDescr.10 = STRING: The MIB module for logging SNMP Notifications.
        SNMPv2-MIB::sysORUpTime.1 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.2 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.3 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.4 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.5 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.6 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.7 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.8 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.9 = Timeticks: (0) 0:00:00.00
        SNMPv2-MIB::sysORUpTime.10 = Timeticks: (0) 0:00:00.00
        HOST-RESOURCES-MIB::hrSystemUptime.0 = Timeticks: (462507) 1:17:05.07
        HOST-RESOURCES-MIB::hrSystemDate.0 = STRING: 2023-11-25,11:21:47.0,+5:30
        HOST-RESOURCES-MIB::hrSystemInitialLoadDevice.0 = INTEGER: 393216
        HOST-RESOURCES-MIB::hrSystemInitialLoadParameters.0 = STRING: "BOOT_IMAGE=/boot/vmlinuz-6.2.0-37-generic root=UUID=72cc58d1-7d2b-4993-b412-49b9460f5031 ro quiet splash vt.handoff=7
        HOST-RESOURCES-MIB::hrSystemNumUsers.0 = Gauge32: 2
        HOST-RESOURCES-MIB::hrSystemProcesses.0 = Gauge32: 282
        HOST-RESOURCES-MIB::hrSystemMaxProcesses.0 = INTEGER: 0
        HOST-RESOURCES-MIB::hrSystemMaxProcesses.0 = No more variables left in this MIB View (It is past the end of the MIB tree)
        Error I am getting
        and OID which is missing
        • vijayk
          • May 2023
          • 305
          Did you check this link?
          https://techexpert.tips/zabbix/zabbi...ux-using-snmp/
          • Vaibhav Ubale
            • Mar 2021
            • 9
            Hi Thanks for your quick reply . Only diffrencei could spot is the "Template OS LINUX SNMPv2" vs "Template OS LINUX SNMP" that I have used.
            I am unable to find this Template OS LINUX SNMPv2 in my templates. I will try to find and assigne.
            • vijayk
              • May 2023
              • 305
              Might be OID is different. I'm not sure for that.
              • vijayk
                • May 2023
                • 305
                Try this tool. It will help you to browse the correct OID.
                How Can We Help You? Should you have any issues with our software, any questions or suggestions, feel free to contact technical support. Please be as complete
                • ISiroshtan
                  • Nov 2019
                  • 324
                  In your config snmpd.conf on Ubuntu you limit the OID trees exposed
                  view systemonly included .1.3.6.1.2.1.25.1​
                  Then from Zabbix you try to request 1.3.6.1.4.1.2021.11.66.0 (from screenshot) which is outside of allowed trees. As SNMP Agent on your Ubuntu does not expose said tree it replies to Zabbix with info that no such oid exist.
                  Fix permissions from Ubuntu side and all should work fine.
                  • Vaibhav Ubale
                    • Mar 2021
                    • 9
                    Thanks @vijayk​ and @ISiroshtan​ for your reply ,
                    @ISiroshtan​, so i need to allow other tree's in my snmpd.conf . is that right or should i remove systemonly?
                    I will try to find and fix this. Thanks .
                    • ISiroshtan
                      • Nov 2019
                      • 324
                      To explain:
                      In configuration
