How to show integers
  • mauricio005
    • Jan 2023
    I am having difficulty displaying numbers where there is the number of impressions, in Recent Data it shows the entire value, for example: 34,564.
    The graph shows the following: 34.56k, I need the entire value to be shown, any tips on how to fix this?​
  • Answer selected by mauricio005 at 28-11-2023, 19:31.
    cyber
    prefix units with "!" for that item. It will prevent this automatic conversion to kilos and megas etc...
    Units​ - Note that if a unit is prefixed with !, then no unit prefixes/processing is applied to item values.​
      • mauricio005
        • Jan 2023
        Thank you very much, that was exactly what I was trying to do, if you could help me with one more thing I would be grateful. How do I leave the formatting so that a period appears after 3 digits, example: 35,256
          No idea... Maybe some general regional settings while setting up Zabbix? I am from the part of the world, where we manage without extra periods..
