How to monitor differents systemd services on differents devices ?
  • Clayzes
    • May 2022
    • 29
    I have to monitor systemd services on differents devices , I'm using the "Systemd by Zabbix agent 2" ,
    I wonder how I could configure the template to implement a "flexible regex".
    So I could monitor different systemd services on depending of the machine but using the same template.
    Thank you
    Define that Macro on host level... If you look into hosts config and go to macros and then "inherited macros" you should see that one coming from template... if press "change" there, you can "replace" it with host level one.
    • Clayzes
      • May 2022
      • 29
      ow , I will try it , Is it possible to use value in the config of the agent in the HostMetadata ?
        HostMetadata is used during autoregistration. You can define different (registration) operations based on it. But there is no option to set macros...
        • Clayzes
          • May 2022
          • 29
          oh ok , because my goal would be to use value on "hostmetadata" and use it as macro on a template so I can monitor different things using the same template
