RHEL 4 Xabbix agent?
  • kkodak66
    • Dec 2023
    Installed server:xabbix 6.4
    agent cannot find RHEL4
    Can anyone tell me where I can download it?​
    • 4970
    RHEL 4 is so ancient, that you do not get any agents for that.
    • solution
      • Jun 2020
      • 272
      wow. very old.
      try this:​
      SNMP?
      Good luck on the adventure.
      Wellington
      • tim.mooney
        • Dec 2012
        • 1436
        The Zabbix 5.0 agent source can be successfully built on RHEL 5.11, so if you know how to configure and compile source code into objects and executables, there's at least a chance that the 5.0 agent could be built on RHEL 4.x. You should be able to run the 5.0 agent with a 6.4 server I believe.
        • kkodak66
          • Dec 2023
          YES, we will use SNMP in the RHEL 4,thanks
          • kkodak66
            • Dec 2023
            this is very old ,
            the RHEL 5 agent can't run ,but thank's for your respond
            • tim.mooney
              • Dec 2012
              • 1436
              this is very old ,
              Sorry I wasn't clear: I wasn't talking about the RHEL 5 agent, I was talking about the Zabbix 5.0.x agent compiled on RHEL 4. I know that the Zabbix 5.0.x agent compiles and works on RHEL 5.11, so I was suggesting there's a chance that it also could be compiled and may work on RHEL 4.x. I wasn't suggesting that you take any version of the agent compiled for RHEL 5 and try run it on RHEL 4. I agree that is very unlikely to work.
              • kkodak66
                • Dec 2023
                i don't know how to use
