i am new with zabbix and install packet 3.0.4 for debian jessie. i used the howto from zabbix and all went well, except the configuration for apache2.6.
1) By default zabbix is installed in /usr/share/zabbix
- that didtn work and i got 404 in browser
-- i copied zabbix dir to /var/www and set permissions to www-data:www-data <- i can visit the website
2) the pre-requiremnt checks run with failure like wrong post_max_size ...
- the apache conf is per default under /etc/apache2/config.d and linked from /etc/zabbix/apache.conf <- values inside are ok
-- it seems that this file is ignored, so what should i do to solve this?
-- i can edit main php.ini but i think thats not the best way
thx for help
thx for help
