HowTo HDD Temperature Monitoring
  • Sunghost
    • Sep 2016
    • 16
    i am new with zabbix and search the web for howto monitor disk temperature with zabbix, but didnt find an up2ate answer. What is the recommend way to do so?
    thx
  • Semiadmin
    • Oct 2014
    • 1625
    The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
    • Sunghost
      • Sep 2016
      • 16
      Thx
      Thx,
      i downloaded it and followed the installation instruction. I import the template and configure the agent, but i have no graph for smart values on host i added the template. Logs seems clear, what can i check?
      thx
      edit: ok i think it is because of missing modules, which i could find under debian jessie.
      • nobodysu
        • Sep 2016
        • 84
        Most likely, you need to add graph prototype in your template's discovery rules, selecting your temperature prototype item. After that your host will have temperature graph.
        I'm using this solution for disk temperature monitoring:
