Latest RPM
  • prsf1233
    • Sep 2016
    Latest RPM
    Hi, I need to install Zabbix in an offline environment Redhat 6 environment so started to download the necessary RPM.
    In the download site is looks like the main 3.0.4 RPM for example the server are in the deprecated directory?
    Graham
  • Atsushi
    • Aug 2013
    • 2028
    Server packages for RHEL 6 is located in the deprecated directory.
    However, it seems that it is a package that is not recommended as the directory name.
    Since RHEL 6 is an older version of the software that is included,
    you can not use all the features of Zabbix 3.0.
    For example, SMTP authentication can not be used.
    And, PHP version requires 5.4 or later.
    As a way to upgrade the PHP 5.4 or later on RHEL 6, the use of SCL will be considered.
