Stuck on Jsonpath pre-processing LLD rule
  • Brambo
    • Jul 2023
    • 256
    Hi I got a jsonoutput where it is structured like the image (deleted values but the structure is valid)
    My master item gets the entire JSON output and it basicly repeats about 44 items​
    In my Discovery item (depended item on the complete json)
    I do preprocessing: $.Applications..Descriptor
    LLD Macro: {#APPNAMES} Jsonpath: $.Name
    This part works with the item prototype
    The key: Supervisor_[{#APPNAMES}] generates items with the correct key names ({#APPNAMES} contains the expected value.
    I'm stuck on getting the blue StatusCode value
    I tried: $..[?@(.Name=='{#APPNAMES}')].Status.StatusCode.first()
    $.Applications.[Supervisors]..[?(@Descriptor.Name=="{#APPNAMES}")] << With single and Double quote tested and supervisors with and without brackets.
    I think I'm close to the solution however even with site jsonpath.com and changing the LLD macro to a value of the Json output I can't get the status code returned
  • Answer selected by Brambo at 07-12-2023, 17:35.
    Brambo
    • Jul 2023
    • 256
    Update by myself.
    It looks like
     $.Applications..Supervisors[?(@.Descriptor.Name=="{#APPNAMES}")].Status.StatusCode
    returns the correct value... now only fix the string / interger issue
    edit: fixed with .first() at the end of the jsonpath.
    • Brambo
      • Jul 2023
      • 256
      Update by myself.
      It looks like
