Simple checks: ambiguous results
  • banzayats
    • Mar 2012
    • 25
    Hello
    I have the following issue. I use simple checks (net.tcp.service[service_name]) to monitor general services such as http, https, ftp, pop etc.
    But some checks (https and ftp) behave very strangely. All hossts notify me that I have the problem: 'HTTPS (FTP) service is down on {HOST.NAME}'
    And indeed - the status of these checks is equal to 0.
    But at the same time, if I run zabbix_get from Zabbix server or proxy:
    zabbix_get -s myhostname.com -k "net.tcp.service[ftp]"
    or
    zabbix_get -s myhostname.com -k "net.tcp.service[https]"
    the result is 1!
    How can this be?
  • Atsushi
    • Aug 2013
    • 2028
    Simple check will check if it can connect to the port from Zabbix server.
    It is can be retrieved using the zabbix_get, check the service in the host from the Zabbix agent.
    Can you connect the server and protocol(port) specified from Zabbix server?
    Do not limit by Firewall?
    • banzayats
      • Mar 2012
      • 25
      Telnet to port 443 works fine. So the firewll rules do not restrict access from zabbix server/proxy.
