Good afternoon all.
Struggling to configure SNMP v3 for a Cisco 3750E with Zabbix 3.0 on CentOS 7. I have been using the Zabbix docs here:https://www.zabbix.com/documentation...itemtypes/snmp
We have the switch set to monitor just CPU and one VLAN, however running snmpwalk past it like this:
I get:
if I'm using snmpwalk -v 3 (or -v3) why does it come back with SNMPv2? I can't get an OID list to add the ones I need into the host item list.
There also seems to be conflicting naming terminology between Zabbix and Cisco so I'm not 100% sure I have the correct config.
In the Host Item we have:
Context name - is that the Cisco group name?
Security name - is it the Cisco user name?
Haven't really used v3 much so any assistance gratefully received.
snmpwalk -v3 -a SHA -A <passwd> -u <cisco_username> -x AES -X <passphrase> -l authPriv <ip>
SNMPv2-SMI::mib-2 = No more variables left in this MIB View (It is past the end of the MIB tree)
