Host Connection Problem
  • guguna
    • Sep 2016
    Hi. I have a problem With adding host to Zabbix monitoring system. I've done everything how it shows YouTube tutorial but Z icon is red. Can you help?
  • tritsako
    • Dec 2014
    • 46
    Hi Guguna,
    You the error "Get value from agent failed" this is connection issue. You have to be sure for the following:
    - zabbix agent is up and running on your host machine.
    - Zabbix server has connection through port 10050 (Firewall setting) to you host and vise versa.
    - the Agent configuration is configured correctly on the host machine
    Costas
