Modbus in Zabbix
  • PAD
    • Dec 2023
    Modbus in Zabbix
    I want to use modbus in Zabbix.
    For this purpose I installed zabbix_agent2.
    What settings should I make in zabbix_agent2.conf file and what in modbus.conf file.
    Currently I have configured modbus.conf like this
    Plugins.Modbus.Timeout
    Plugins.Modbus.Sessions.MB1.Endpoint=tcp://xxx.xxx.xxx.yyy:502 (xxx.xxx.xxx.yyy its modbus device address )
    Plugins.Modbus.Sessions.MB1.SlaveID=1
    Plugins.Modbus.Sessions.MB1.Timeout=10
    But I don't know what settings to put on zabbix_agent2.conf​
  • Answer selected by PAD at 15-12-2023, 11:21.
    jeansieb
    • Jan 2023
    Originally posted by PAD
    I get an error message
    Testing
    root@zabbix01:/etc/zabbix# zabbix_agent2 --test "modbus.get[tcp://xxx.xxx.xxx.yyy:502,2,1,04100,1,,,1]" (xxx.xxx.xxx.yyy device IP)
    Answer
    modbus.get[tcp://xxx.xxx.xxx.yyy:502,2,1,04100,1,,,1][m|ZBX_NOTSUPPORTED] [Unable to read: read tcp xxx.xxx.xxx:56372->xxx.xxx.xxx.yyy:502: i/o timeout]
    (xxx.xxx.xxx Zabbix server IP)
    Where am I wrong​
    Also getting the same error.
    I can see with a tcpdump that the network packets are going back and forth between Zabbix and the host, but it seems like something is missing from Zabbix to understand what info is coming back.
    • PAD
      PAD commented
      Do you have any idea where I need to adjust in Zabbix,
    • 5002
    Make sure you have Include parameter in your agent2 config so your modbus conf will be included... nothing else, I think...
    • PAD
      PAD commented
      I had Include=/etc/zabbix/zabbix_agent2.d/*.conf
      Now it is Include=/etc/zabbix/zabbix_agent2.d/modbus.conf
  • PAD
    • Dec 2023
    Testing
    Answer
    Where am I wrong​
    • jeansieb
      • Jan 2023
      Testing
      Answer
      Where am I wrong​
      • PAD
        PAD commented
