Monitor Fortigate VPN Status phase 1
  • r4pperbr
    • Mar 2023
    Guys, good morning!
    Can you help please? I'm monitoring Fortigate VPNs and I would like to know if I can only monitor the status of phase 1 of the VPN, as phase 2 has multiple connections and ends up polluting the monitoring screen, I tried several alternatives but without success. Another situation I noticed is that if at least one of the vpn's phase 2s goes down, the trigger goes off, and phase 1 only goes down if all phases 2 also go down, am I right?
    Below are images of the applied configuration.,
  • Cassemiro
    • Apr 2024
    good afternoon,
    managed to find out how to monitor phase 1 of the fortgate vpn through zabbix, I'm experiencing the same problem.
    • gtaipe
      • Jul 2022
      I solved the issue using preprocessing. This preprocessing creates a consolidated JSON with the VPN status: 2 if at least one phase is active, and 1 if all phases are down.
