database upgrade failed on patch 06000011, exiting in 10 seconds
  • wwwzebra
    • Dec 2023
    • 19
    Hello!
    Ubuntu 22.04.3LTS
    Zabbix 5.4 --> 6.0.25
    After upgrading get an error on 89%
    sudo cat /var/log/zabbix/zabbix_server.log | grep database
    ...89%
    10944:20231214:174501.412 starting automatic database upgrade
    10944:20231214:174501.413 database upgrade failed on patch 06000011, exiting in 10 seconds
    10944:20231214:174511.416 database could be upgraded to use primary keys in history tables
    10957:20231214:174521.675 current database version (mandatory/optional): 06000000/06000010
    10957:20231214:174521.675 starting automatic database upgrade
    10957:20231214:174521.677 database upgrade failed on patch 06000011, exiting in 10 seconds
    What can I do?
    Thx​
    • 5002
    Reread all the prerequisites for upgrade. all the DB related permissions etc.. I suspect there are some DB settings you must tweak...
    Currently it fails with adding a trigger to hosts table...
    static int DBpatch_6000011(void)
    if (SUCCEED == DBtrigger_exists("hosts", "hosts_name_upper_insert"))
    zabbix_log(LOG_LEVEL_WARNING, "hosts_name_upper_insert trigger for table \"hosts\" already exists,"
    " skipping patch of adding it to \"hosts\" table");
    return SUCCEED;
    return zbx_dbupgrade_attach_trigger_with_function_on_inse rt("hosts", "name", "name_upper", "upper", "hostid");
    • wwwzebra
      • Dec 2023
      • 19
      Thank You for answer
      All was done by this article
      Upgrade Zabbix (5.0, 5.2, 5.4) to 6.0 like a Pro [+6.0 to 6.4 guide] (bestmonitoringtools.com)​
      May be I need to do something before update? (It's VM and I have snapshots)
      How or where can I see? Is there any scripts - to check DB?
      Thx
      • wwwzebra
        • Dec 2023
        • 19
        Tried to do again, using this article
        I did this first:
        mysql> SET GLOBAL log_bin_trust_function_creators = 1;
        as it was recomended https://www.zabbix.com/documentation...rade_notes_640
        And after that
        wget https://repo.zabbix.com/zabbix/6.5/u...u22.04_all.deb
        sudo dpkg -i zabbix-release_6.5-1+ubuntu22.04_all.deb
        sudo apt update
        sudo apt upgrade
        sudo service zabbix-server start
        and checked DB
        98919:20231215:151615.339 current database version (mandatory/optional): 05040000/05040001
        98919:20231215:151615.340 starting automatic database upgrade
        98919:20231215:151615.359 completed 0% of database upgrade
        98919:20231215:151615.456 completed 1% of database upgrade
        98919:20231215:151635.006 completed 98% of database upgrade
        98919:20231215:151635.301 completed 99% of database upgrade
        98919:20231215:151635.423 completed 100% of database upgrade
        98919:20231215:151635.589 database upgrade fully completed
        98919:20231215:151635.591 database could be upgraded to use primary keys in history tables
        As far as I can understand - DB was upgraded and now it works fine?
        I need only to "...upgradу to use primary keys in history tables"
        Yes?
          • 5002
          yes... now it works but could be upgraded some more... with primary keys.
          • shay123
            • Mar 2023
            hi I have the same issue with import DB from 6.4 to 7
            137870:20240716:202049.698 database upgrade failed on patch 06050013, exiting in 10 seconds
            DetailsCannot connect to the database.
            • The Zabbix database version does not match current requirements. Your database version: 6050012. Required version: 7000000. Please contact your system administrator.
            ​help please?
            tried everything on top anyone tried to update recently?
            • krawler656
              krawler656 commented
              step 1: service zabbix-server stop
              step 2: mysql -u root -p
              step 3: SET GLOBAL log_bin_trust_function_creators = 1;
              step 4: service zabbix-server start
              step 5: tail -f /var/log/zabbix/zabbix_server.log|grep database
          • kuPyxa
            • Dec 2024
            help please?
            Try checking MySQL error log. In my case group replication was enabled, just disable it during upgrade.
