Zabbix 6.4.8 LDAP
  • plissj@cotsworks.com
    • Nov 2023
    • 12
    Zabbix 6.4.8 LDAP
    So im having a real issue trying to get LDAP configured.
    I have ubuntu 22.04 latest updates
    zabbix 6.4.8
    installed my root ca cert on Ubuntu
    I can use ldap and ldaps from the console and connections work correctly.
    When I configure ldap in zabbix then try to test I get this error
    I know the login im testing with creds are correct.
    Whats more interesting is I have my base dn in quotes since it has spaces however if I place the Bind DN in quotes I get cant bind to LDAP. No quotes and I get this error.
    Ive been searching and it seems there isnt much on LDAP connectivity to Active Directory.
    So is no one using AD or are they having no issues ?
    Where are the LDAP connectivity logs that might help point m in the right direction ?
    The documentation on this feature seems very lacking.
