UserParameter returns Text, need Integer
  • danims
    • Feb 2012
    Hello
    I'm sure this is an easy one and has been asked before - though I didn't find it.
    I have a UserParameter like this:
    UserParameter=asterisk.num_registered_sip,asterisk -r -x "sip show registry" | grep -c Registered
    On the zabbix agent's machine, I get a text result (probably because bash has no data types):
    root@amy:~# zabbix_agentd -t asterisk.num_registered_sip
    asterisk.num_registered_sip                   [t|2]
    But when I get the information on the Zabbix server, the result is 0:
    root@primrose:~# zabbix_get -s amy -k "asterisk.num_registered_sip"
    0
    Why is that?
  • danims
    • Feb 2012
    Solved
    Ah, nevermind. I ran it locally with User root. I forgot to use sudo in the check.
