Frontend Setup Automation - How?
  • juliusk
    • Dec 2023
    Hey!
    I currently try to automate the process of creating zabbix instances on a rocky linux 8 machine.
    It seems to work so far but if i visit the zabbix.domain.de/zabbix the first time it wants me to go through the gui where i mainly have to type in the Postgresql DB password.
    After some research i have read that i can put a pre-configured "zabbix.conf.php" file in place to skip this process.
    My Problem:
    I cannot find the zabbix.conf.php file which has been generated by my manual installation and where i am supposed to put the pre defined one. All i found is a "/usr/share/zabbix/conf/zabbix.conf.php.example".
  • solution
    • Jun 2020
    • 272
    The default Zabbix Web conf path is: /etc/zabbix/web/zabbix.conf.php
    Wellington​
    • juliusk
      • Dec 2023
      Thanks! Found it.
      So i tried to put that in place before installing Zabbix, but it still wants me to go through the GUI Setup process.
      • juliusk
        • Dec 2023
        Update: Seems like the permissions of the file havent been set correct. After fixing the Permissions it works fine now!
        • irontmp
          • Sep 2023
          • 98
          Originally posted by juliusk
          Hey!
          After some research i have read that i can put a pre-configured tree removal service durham nc"zabbix.conf.php" file in place to skip this process.
          My Problem:
          Issue in 2023.7.1
          When I search for a device (Search for ‘friendly name’) to use it as a trigger for an automation I didn’t find it even though it is in the Picklist of all devices.
          This happens with some devices (no matter what type of integration), but not with all
          Works fine with 2023.6
          Steps to reproduce the issue
          1. Start to create a new automation
          2. Select devices as a trigger
          3. search for device by entering the name (friendly name)
          Anyone else can confirm this issue?
