In the Virt VMware Guest template there is a Mounted filesystem discovery. There are no graphs prototypes associated with this discovery.
If I try to create a graph prototype, the only items I can add are those of the VMware Guest template and not any of the filesystem's prototype items.
Is there anyway to add a graph to the discovered file system on a VM guest?
Zabbix versions 2.4 and 3.0
