Hi All,
So I have a network 192.168.0.1-254, I have configured the Discovery rule as such:
IP Range: 192.168.0.1-254
Checks: system.uname
Device Uniqueness: Hostname
Action:
Conditions:
A Discovery check = Development 10.180: Zabbix agent "system.uname"
B Received value like Linux
Operations:
Link to template.
Now this never works. I never get hosts appear in the template. It will only work if I add a ping check in, and add that to the Actions conditions.
What is stopping Zabbix from going out and discovering the hosts?
The agent is all setup on the clients. I can use zabbix_get from Zabbix to the hosts to verify it can access the hosts data.
I have used netstat on the Zabbix machine as follows:
netstat -tnuap | grep "10050" to try and verify that it's going out and connecting to machines to pull the initial data for discovery. But there is nothing.
Any help is much appreciated.
Action:
Conditions:
Operations:
Link to template.
