zabbix mibs errors
  • mulbzh
    • Nov 2014
    • 115
    zabbix mibs errors
    when i start zabbix server, i have a lot of mibs errors in log, do you think it is normal ?
    44918:20160920:093632.192 Starting Zabbix Server. Zabbix 3.0.4 (revision 61185) .
    44918:20160920:093632.192 ****** Enabled features ******
    44918:20160920:093632.192 SNMP monitoring: YES
    44918:20160920:093632.192 IPMI monitoring: YES
    44918:20160920:093632.192 Web monitoring: YES
    44918:20160920:093632.192 VMware monitoring: YES
    44918:20160920:093632.192 SMTP authentication: YES
    44918:20160920:093632.192 Jabber notifications: YES
    44918:20160920:093632.193 Ez Texting notifications: YES
    44918:20160920:093632.193 ODBC: YES
    44918:20160920:093632.193 SSH2 support: YES
    44918:20160920:093632.193 IPv6 support: YES
    44918:20160920:093632.193 TLS support: YES
    44918:20160920:093632.193 ******************************
    44918:20160920:093632.193 using configuration file: /etc/zabbix/zabbix_server.c onf
    44918:20160920:093632.231 current database version (mandatory/optional): 030000 00/03000000
    44918:20160920:093632.231 required mandatory version: 03000000
    44918:20160920:093632.461 server #0 started [main process]
    44921:20160920:093632.464 server #3 started [poller #1]
    44920:20160920:093632.464 server #2 started [db watchdog #1]
    44922:20160920:093632.465 server #4 started [poller #2]
    44923:20160920:093632.470 server #5 started [poller #3]
    44919:20160920:093632.474 server #1 started [configuration syncer #1]
    44924:20160920:093632.474 server #6 started [poller #4]
    44926:20160920:093632.475 server #8 started [unreachable poller #1]
    44925:20160920:093632.476 server #7 started [poller #5]
    44927:20160920:093632.478 server #9 started [trapper #1]
    44928:20160920:093632.480 server #10 started [trapper #2]
    44929:20160920:093632.483 server #11 started [trapper #3]
    44930:20160920:093632.494 server #12 started [trapper #4]
    44932:20160920:093632.496 server #14 started [icmp pinger #1]
    44931:20160920:093632.496 server #13 started [trapper #5]
    44933:20160920:093632.498 server #15 started [alerter #1]
    44934:20160920:093632.500 server #16 started [housekeeper #1]
    44935:20160920:093632.502 server #17 started [timer #1]
    44938:20160920:093632.512 server #20 started [history syncer #1]
    44941:20160920:093632.516 server #23 started [history syncer #4]
    44939:20160920:093632.517 server #21 started [history syncer #2]
    44940:20160920:093632.517 server #22 started [history syncer #3]
    44936:20160920:093632.519 server #18 started [http poller #1]
    44947:20160920:093632.556 server #25 started [proxy poller #1]
    44948:20160920:093632.584 server #26 started [self-monitoring #1]
    44946:20160920:093632.584 server #24 started [escalator #1]
    Bad operator (INTEGER): At line 73 in /usr/share/mibs/ietf/SNMPv2-PDU
    Unlinked OID in IPATM-IPMC-MIB: marsMIB ::= { mib-2 57 }
    Undefined identifier: mib-2 near line 18 of /usr/share/mibs/ietf/IPATM-IPMC-MIB
    Expected "::=" (RFC5644): At line 493 in /usr/share/mibs/iana/IANA-IPPM-METRICS- REGISTRY-MIB
    Expected "{" (EOF): At line 651 in /usr/share/mibs/iana/IANA-IPPM-METRICS-REGIST RY-MIB
    Bad object identifier: At line 651 in /usr/share/mibs/iana/IANA-IPPM-METRICS-REG ISTRY-MIB
    Bad parse of OBJECT-IDENTITY: At line 651 in /usr/share/mibs/iana/IANA-IPPM-METR ICS-REGISTRY-MIB
    44937:20160920:093635.241 server #19 started [discoverer #1]
    44918:20160920:093641.625 Got signal [signal:15(SIGTERM),sender_pid:45005,sende r_uid:0,reason:0]. Exiting ...
    44918:20160920:093643.627 syncing history data...
    44918:20160920:093643.627 syncing history data done
    44918:20160920:093643.627 syncing trends data...
    44918:20160920:093643.679 syncing trends data done
    44918:20160920:093643.680 Zabbix Server stopped. Zabbix 3.0.4 (revision 61185).
    thanks
  • mulbzh
    • Nov 2014
    • 115
    ok, i have just uncomment /etc/snmp/snmp.conf mibs like this :
    # As the snmp packages come without MIB files due to license reasons, loading
    # of MIBs is disabled by default. If you added the MIBs you can reenable
    # loading them by commenting out the following line.
    #mibs :
    • kloczek
      • Jun 2006
      • 1771
      It is not zabbix error.
      Parsing MIBs is done by net-snmp libraries. As long as you've registered MIB incorrectly or there are some MIB errors you will be able to see such error logs.
