How to monitor a particular port listening status or service
  • nareshkumarvn
    • Nov 2015
    I want to monitor the status of Tomcat that runs on 8080
    Similarly MongoDB - 27017 and redis - 6379
    Note: I don't want to use JMX for Tomcat.
    Thank you
  • guzzijason
    • Dec 2015
    • 106
    did you take a look at the net.tcp.* items in the agent documentation? Sounds like that's what you want.
    __Jason
    • nareshkumarvn
      • Nov 2015
      __Jason
      Thank you Jason
      I used net.tcp.port[<ip>,port]
      Example:
      ⇒ net.tcp.port[,80] → can be used to test availability of web server running on port 80
      I cloned the NTP template and create a template for MySQL, Just changed the names and updated 'key' value for the 'item' as given below
      net.tcp.port[,3306]
      I'll create similar templates for mongoDB and redis.
      Thanks Again !
