Problem reporting issues
  • YoungbloodMat
    • Dec 2023
    Hi All,
    Is there a way to tell the Zabbix agent the difference between two discs - Say, the main one and mounted block storage?
    I have a trigger telling me that the main storage disc is at 90% full, but, it seems to be reading the mounted disc as part of the main one.
    The server with the alleged issue:
    Ubuntu 22.04
    2 Core
    2GB
    50GB
    Disks:
    50GB vda Primary Disk (Operating System)
    150GB vdb
    I've manually run: du -sh */ | sort -hr in CLI which gives me the return:
    42G mnt/ < being the seperate storage disk.
    1.9G var/
    1.5G snap/
    790M lib/
    569M usr/
    242M bin/
    113M boot/
    58M sbin/
    7.8M etc/
    2.3M root/
    984K run/
    72K tmp/
    44K home/
    16K lost+found/
    4.0K srv/
    4.0K opt/
    4.0K media/
    4.0K libx32/
    4.0K lib64/
    4.0K lib32/
    0 sys/
    0 proc/
    0 dev/
    Thank You,
    May the force be with you!
    Youngblood #10
