Zabbbix SNMP CCM status
  • seky
    • Sep 2016
    I have a Cisco Call Manager and 2 devices in cluster and I want to monitor status of each node in this cluster
    SNMP OID is: 1.3.6.1.4.1.9.9.156.1.1.2.1.5 ( ccmStatus )
    When I run command like that:
    snmpwalk -v2c -c test cucm1.test 1.3.6.1.4.1.9.9.156.1.1.2.1.5
    SNMPv2-SMI::enterprises.9.9.156.1.1.2.1.5.1 = INTEGER: 2
    SNMPv2-SMI::enterprises.9.9.156.1.1.2.1.5.2 = INTEGER: 2
    I get a following output, showing that there is 2 devices and their status is OK, so next I want to create Zabbix item type of SNMPv2 Agent, but I dont know what I need to type into SNMP OID field, I need to use dynamic indexes or something like that? If yes, how can I do this?
    If I created with SNMP OID 1.3.6.1.4.1.9.9.156.1.1.2.1.5.2 ending with .2 I was only monitoring second device in cluster and its status, it is possible to create one item and monitor all devices in this cluster?
    Thank you so much.
