Host Scripts menu has disappeared in 3.2 in triggers/problems section
  • okelet
    • Sep 2016
    • 18
    After upgrading to Zabbix 3.2, the menu that appears when clicking the host name showing scripts doesn't exist ("Go to" do appear). The same happens in the problems section; in the dashboard, the action menu does appear.
    Is this change a feature or an error? Or is now an option?
  • BIOS
    • Oct 2016
    It looks like a bug.
    Variable $hostids is associative array now, but getScriptsByHosts() didn't expect this.
    • okelet
      • Sep 2016
      • 18
      Thanks! Do you know if there is an already open bug?
      • okelet
        • Sep 2016
        • 18
        Found (and fixed): https://support.zabbix.com/browse/ZBX-11329
