Template "depth"
  • Calimero
    • Nov 2006
    • 481
    Template "depth"
    I'm wondering whether there's any limit (be it a "hard coded limit" or a "performance limit") on how deep templates can be cascaded/inherited.
    Ex:
    WebServer_t
    - item/trigger: HTTP port
    - item/trigger: ICMP Ping
    WebServer_Linux_t, linked with WebServer_t
    - item/trigger: SSH port
    WebServer_Linux_SNMP_t (same goes with agent), linked with WebServer_Linux_t
    - SNMP items/triggers: disk usage, custom scripts...
    Even WebServer_t could actually be the child of "Server_t" (which would have ICMP Ping while Webserver_t would only have HTTP).
    So far I haven't played with template inheritance. I've created simple "flat" templates like:
    Linux_SNMP_t
    - simple check ping + trigger
    - simple check ssh + trigger
    - simple check http + trigger
    - snmp query disk usage + trigger
    Windows_agent_t
    - simple check tcp,3389 + trigger
    - agent disk usage + trigger
    And I end up with two "HTTP down" (on from each template/trigger) lines in the overview window. This also means I spend (waste !) more time creating each template.
    Well: is template inheritance limited in depth ? is it a performance killer ?
    Thanks !
    Calimero
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    There is no depth limit and the depth level does not affect performance at all.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Calimero
      • Nov 2006
      • 481
      Sweet !
      • ericg
        • Apr 2023
        • 15
        Sorry to bring up such an old thread, but I'm wondering if this is still true today at Zabbix 7.0/7.4?
