Zabbix 6.4 - Use macro {HOST.DESCRIPTION} in title hof Host, Trigger, Inventory
  • sxboxer
    • Jan 2024
    Hello, everyone. I've come across a problem I can't solve. I need to somehow auto-complete the Host Description to the Host name. Another use I would have is also as a Trigger name {TRIGGER.NAME} - {HOST.DESCRIPTION}, but when I type the macro into Title like this, it only shows "{TRIGGER.NAME} - {HOST.DESCRIPTION} without adding the value. According to the documentation this is possible, so what am I doing wrong that it doesn't work ? For complete information I use Zabbix version 6.4
    Really thanks for you help
    Are you sure you are using those macros in places mentioned in docs? You description of problem does not tell much about what and where exactly are you doing...
