Using Proxmox VE by HTTP Template
  • am0nrahx
    • Jul 2018
    Apologies if this has already been discussed and resolved, my searches did not yield anything satisfactory.
    I have a fresh install of both Zabbix and Proxmox.
    I am running Zabbix 6.0.25 and Proxmox 8.1.3.
    I have installed the agent like normal. I am not using the active agent.
    I've added the api information for the root user. This server is used locally in my home lab so I didn't see the necessity to add a second user for the API.
    The port macro is also correct.
    When trying to force the discovery items, it is giving me the following:
    Cannot send request[LIST][*]Cannot send request: wrong discovery rule type.[/LIST]
    zz0.tc26r0n886zz
    Further, I have an error on the cluster discovery item.
    Invalid discovery rule value: cannot parse as a valid JSON object: invalid object format, expected opening character '{' or '[' at: 'Error getting data'​
    I've not modified the template except the API macros. It is being used as it ships with Zabbix.
    Can anyone tell me what I'm doing wrong?
  • b3nw
    • Jul 2017
    having same issue here:
    Debian 12, Zabbix 6.4.13, Proxmox 8.1.10
