Zabbix trigger for unused eternet port, trigger when not enough data is available
  • digit23
    • Aug 2021
    I'm using zabbix 6.4
    Basically I try to have a report of all ethernet port not used for 30 days on a switch.
    My trigger look like this
    count(/Switch/net.if.status[ifOperStatus.{#SNMPINDEX}],30d,"ne",2) = 0
    Where ifOperStatus 2 mean link down. So if for the last 30d there is no other value than 2, tiggers.
    Problem is, when a new switch is added with some ports down, there is only one value for that port which is 2, so it trigger.
    I don't want to trigger if there is less than 30d of value to be checked. How to do that ?
  • digit23
    • Aug 2021
    Is that OK ? Better way ?
    # Check 30d ago if we have link down status, if so = true
    count(/Sophos C-Switch by SNMP test/net.if.status[ifOperStatus.{#SNMPINDEX}],1d:now/d-30d,"eq",2) <> 0
    and
    # Check all available status for last 30d, if all down = true
    count(/Sophos C-Switch by SNMP test/net.if.status[ifOperStatus.{#SNMPINDEX}],30d,"ne",2) = 0​
    • digit23
      • Aug 2021
      I hink that will work
      count(/Sophos C-Switch by SNMP test/net.if.status[ifOperStatus.{#SNMPINDEX}],1d:now/d-29d) <> 0
      and
      • cjbruck
        • Jun 2024
        • 11
        Thanks for sharing this. Very useful in finding an unused port when all ports are connected.
