Aruba Network Monitoring
  • Chan_Mon
    • Jan 2024
    Is there any chance to help me with the Aruba Switch ( 3810M, 2540 ) Monitoring template and please also help me with SNMP configuration on that switch .
  • MRedbourne
    • Feb 2023
    • 103
    We need more information than that to help you.
    1. What version of Zabbix are you using? (Ex: 6.4.10)
    2. What template are you using?
    3. What version of firmware are the 2540 and 3810Ms using?
    4. What assistance do you need with the switch configuration? (Setting up SNMP?)
    5. Can you describe the current issue you're having?
