Trigger debugging / CLI interface
  • digit23
    • Aug 2021
    Is there a "live" CLI interface where we can type trigger expression for dev and debug purpose ?
    What is your developpement workflow when creating triggers ?
    Under "Expression" field is a link "Expression constructor". Clicking there will also reveal a "Test" button...
    • digit23
      • Aug 2021
      The expresseion constructor allow to test expression with arbitraty value but not with real data set. It this te only tool to build triggers ?
        But what's wrong with arbitrary values? You can enter whatever there and test your expression outcome, why it has to be live data?
        • digit23
          • Aug 2021
          That's not wrong. But when you do computational (count, avg, max, min) working on real data, making sure you get result that you need in a realtime CLI interface could be a better trigger developement workflow.
            Ok, I see... But I never bothered.. I probably trust Zabbix enough, that it can manage with counting things and giving out min/max values..
