Zabbix HA cluster: sync configurations between nodes?
  • olegus
    • Dec 2023
    • 71
    Is it a way to automatically sync configuration changes between servers in Zabbix HA cluster? Or should i repeat updates on each of nodes?
    I.e. if I add a Host group/template or an Alert action, should I do this on every node or only on Active node and they will be replicated on passive ones?
    EDIT: Answering to myself - as all nodes talk to the same DB, configuration changes will be seen from all nodes
    Last edited by olegus; 10-01-2024, 18:07. Reason: Realized that all servers connect to the same DB, duh :)
