Asterisk monitoring through zabbix
  • gauravfz
    • Sep 2016
    Hi i am trying to monitor sip and iax peers by configuring the zabbix agent (userparameter)
    UserParameter=sip1key,asterisk -r -x 'iax2 show peer peername' | grep Status | grep OK | wc -l
    at the zabbix server , while creating item using sip1key , it shows not supported by zabbix and not being monitored , please help...
    Or there is any other way i can monitor asterisk sip peers/trunks throgh zabbix...
  • unficyp
    • Dec 2014
    • 27
    did you reload the zabbix agent ?
    userparams are enabled at the agent side ?
    zanbix user on asterisk host can call asterisk binary ?
    maybe some sudo / chmod adjustments are neccessary.
    • gauravfz
      • Sep 2016
      Yes i did.
      Zabbix parameter enabled?
      I believe that if UnsafeUserparametrs=1 , means it enables , if anything else please let me know...
